"Sync completed" sound doesn't play
I've set a sound in the settings menu for "Sync completed" but it never plays. The file scan completed sound does play, but not the sync completed sound.
not sure if you found a fix for this, I'm on Kubuntu, I installed 11.25 no notification sounds were play9ing either, I had to roll back one version.
I'm currently using 11.23.
I haven't found a fix for this. I'm on windows and no version has ever worked. I've tried changing the sound and stuff but nothing. The comparison completed sound does indeed work
This has been fixed in FFS 11.26.not sure if you found a fix for this, I'm on Kubuntu, I installed 11.25 no notification sounds were play9ing either, I had to roll back one version.
I'm currently using 11.23. nootzee, 07 Sep 2022, 02:40
Sweet, thanks!This has been fixed in FFS 11.26. Zenju, 07 Sep 2022, 07:35
lol :-) um, guys am I in a different internet subnet - I don't see the 11.26 download.
The official 11.26 version is not available yet (status 8 September 2022), but given the rate at which Zenju releases updates, you can likely expect v11.26 pretty soon.
