Hello "
I'm syncing from one NAS to another (rights are ok). I noticed missing new dirs being created from left to right side but dont know why. Sync settings are "Newer to right, syncronize right and sync when different" ... and no action on newer files on right side etc.
Should FFS copy new dirs to right side automaticly - i think yes ? Do i miss something ?
FFS 11.17 - not copying new dirs
"Newer to right, syncronize right and sync when different" is not a real description so putting it in quotes makes no sense.
"I noticed missing new dirs being created from left to right side" but then "Should FFS copy new dirs to right side automaticly - i think yes".
You said it's doing exactly what you expect. What's the question?
FFS is not copying new dirs from left to right and dont know why. I'm using quotes just to explain which green arrows are set :-) Exclude list is NOT the problem.
Do they show up after running a compare?
Sorry - just checked - my fault - i selected a wrong path (missing subdir). Ashes on my head.
Lol, no problem. At least it was something easy!
