Forget the recycle bin
rossn
How do i sync, where FFS forgets the recycle bin exists.
FFS continually trying to sync the recycle bin is causing me no end of problems. Its will soon be a delete program issue.
Select your left right pair(s) so it does not include your/a recycle-bin,
or add the recycle-bin folder(s) to your Exclude Filter.
The latter can be easiest done by running a Compare in FFS, in the Compare result window select the recycle-bin folder(s) and via the right-click context menu add the recycle-bin folder to the Exclude Filter.
P.S.
The default Exclude Filter should already comprise the standard recycle-bin location.
