Does Detect Moved Files work for Mirror syncs?
Radish
Does 'Detect Moved Files' work if one is using the 'Mirror' variant for doing syncs?
As far as I know it should, when enabled.
But note that 'Detect Moved Files' only works for file systems and OS's that have (cross restart) stable file-IDs.
Radish
Thanks very much Plerry. I had to ask as I find the Manual a bit ambiguous on this subject (at least by my reading).
But note that 'Detect Moved Files' only works for file systems and OS's that have (cross restart) stable file-IDs.Plerry, 20 Feb 2022, 15:12
I'm on Windows 7 so I will assume that it can/does do that.
Thanks again.
NTFS does support stable file-IDs
Radish
Thanks very much for the information, xCSxXenon. Good to go!
