Real time sync autostart and Google drive
leotordo
Hello everyone.
Sorry but I'm not very skilled with this program.
I need to mirror my work folder on gdrive
I setted up File Sync (my folder on the left, gdrive on the right)
Sync works properly manually
The problem is RealTime. I saved SyncWork.ffs_batch file from FileSync (green app) and opend in RealTimeSync (red app). When I open it there are both folder (local and gdrive) loaded and program fails beacause it can monitor gdrive folder. If I remove gdrive folder leaving local only the RealTime works properly.
So...I do some mistake saving ffs_batch file?
I whant to autostart RealTimeSync at power on of the system
Thank you
Stefano
You can't use RTS with Google Drive
leotordo
You can't use RTS with Google Drive xCSxXenon, 22 Feb 2022, 19:39
if I laucnh RTS with batch command giving ffs_batch file it appears like that
and doesn't work
If I manually remove references to gdrive
it works and syncs to gdrive but doesn't starts automatically beacause in ff_batch file there are gdrive links too
Stefano
That shouldn't matter. It's more likely that one of your locations changes more often than every 10 seconds, so the idle time never triggers.
leotordo
Solved: from working RTS I saved ffs_real config file then I put a link to
"C:\Program Files\FreeFileSync\RealTimeSync.exe" "C:\SyncPersonal.ffs_real"
into startup folder
Stefano
