Feature Request: Sync single folder pair command (button)
Darko
Hi, it would be nice if we could have a button to perform comparison/sync of a single row (folder pair) instead of entire list / job list. E.g. if we know only single pair is affected, we can save a lot of time instead of performing a full comparison scan. Thanks!
You can always remove a folder pair from a list of pairs by clicking the minus-icon in front of a pair.
You can then always restore to the full folder pair list by restoring the saved initial sync configuration,
e.g. by clicking that configuration in the FFS GUI top-left Configuration window.
Alternatively, you divide your total list of pairs into (non-overlapping) individual pairs or smaller groups of pairs and save those sync configurations individually under recognizable names.
In the FFS GUI Configuration window, now simply select or deselect the desired sync configurations, and the list of left-right pairs will be adjusted accordingly.
Darko
Hi Plerry,
yeah, I do that sometimes, but when you have 20+ folder pairs defined, it's a bit tedious work. Having a local sync button next to the right row would be awesome feature.
mBrane
Likewise, it would be nice to have an enable/disable button for each fold pair... right next to this new "go" button! Will drop my own feature request for this, but *so* closely related! :)
UPDATE: Related Feature Request submitted:
viewtopic.php?t=10642
