After the last onedrive update, which does not provide an option to keep local files by default, there appears to be a constant sync issue, as FileSync apparently cannot make changes in the onedrive folder although the files are locally downloaded. There must be some sort of bug or issue in handling the local files, as FileSync does spot the changes in the files, but it cannot process the changes, i.e. update with newer versions or delete documents in the destination folder. The issue is entirely related to onedrive as syncing with other local folders is going on smoothly as previously.
Any ideas or ways to fix this?
Thanks in advance
Syncing issue with local folders after latest onedrive update
Are you syncing with "C:\Users\XXXXXX\OneDrive"?
Are you referring to the "on demand" option? I still have that and OneDrive saves files locally by default still.
