Context menu won't change language in Explorer
Sopor
When i install FFS it will use Swedish, but i run everything in English, so i change language of FFS to English after installation.
The problem is that the context menu "Edit with FreeFileSync" is still in Swedish (Redigera med FreeFileSync) after i change language of FFS.
Computer\HKEY_CLASSES_ROOT\FreeFileSync.ffs_batch.1\shell\edit
Computer\HKEY_CLASSES_ROOT\FreeFileSync.ffs_gui.1\shell\edit
This is where that text is stored and can be changed, if you are comfortable fixing them manually.
