[suphicakir@turquoise freefilesync]$ ./FreeFileSync
(FreeFileSync_x86_64:29957): Gtk-WARNING **: 09:45:19.472: Unable to locate theme engine in module_path: "adwaita",
Error starting "/opt/freefilesync/Bin/FreeFileSync_x86_64".
Killed by signal 11
FreeFileSync does not work on Arch-based Linux distributions.
Hello Community. I installed MX Linux on my computer before and when I installed FreeFileSync it worked. In all arch Linux based distributions this app definitely didn't work. The console output is as follows:
What can I do about it? can you help me?
Clearly you have gtk3. There isn't a whole lot of info in your error message. Can you run:
This will show us the linked libraries. There should be the generic libs like libc6.so and libgtk3. Make sure all entries in that list exist. Perhaps you're missing a dependency. MX Linux is based on Debian and the debian dependency list is well-defined: these are package names below.
SELinux would be optional.
Perhaps additionally you could run
Right after the failure, so we can see the exit code. Maybe, and just maybe, the application has some mechanisms for error handling that could help troubleshoot.
ldd /opt/freefilesync/Bin/FreeFileSync_x86_64
Depends: libc6 (>= 2.33)
libcurl4 (>= 7.68.0)
libgcc-s1 (>= 3.0)
libgdk-pixbuf-2.0-0 (>= 2.31.1)
libglib2.0-0 (>= 2.16.0)
libgtk-3-0 (>= 3.0.0)
libselinux1 (>= 3.1~)
libssh2-1 (>= 1.7.0)
libssl1.1 (>= 1.1.1)
libstdc++6 (>= 7)
libwxbase3.0-0v5 (>= 3.0.5.1+dfsg)
libwxgtk3.0-gtk3-0v5 (>= 3.0.5.1+dfsg)
zlib1g (>= 1:1.2.0)
xdg-utils
echo $?
Hello ! I am encountering the same problem. Here is what the `ldd` command returns me :
And now, here is what I have when running my .sh file that contains this :
Could you please help me ?
I have installed gtk-adwaita but nothing's changing : the error remains the same
By the way, I am runing a Kubuntu distro (KDE)
However, everything is working well when using the graphical interface and realtimesync app. The only problem is when trying to use a command (I need it in order to launch the sync at startup)
ldd /opt/FreeFileSync/Bin/FreeFileSync_x86_64
linux-vdso.so.1 (0x00007fff38379000)
libgthread-2.0.so.0 => /lib/x86_64-linux-gnu/libgthread-2.0.so.0 (0x00007f54b5c6c000)
libX11.so.6 => /lib/x86_64-linux-gnu/libX11.so.6 (0x00007f54b5b2e000)
libXxf86vm.so.1 => /lib/x86_64-linux-gnu/libXxf86vm.so.1 (0x00007f54b5b27000)
libxkbcommon.so.0 => /lib/x86_64-linux-gnu/libxkbcommon.so.0 (0x00007f54b5ae1000)
libgtk-x11-2.0.so.0 => /lib/x86_64-linux-gnu/libgtk-x11-2.0.so.0 (0x00007f54b5600000)
libgdk-x11-2.0.so.0 => /lib/x86_64-linux-gnu/libgdk-x11-2.0.so.0 (0x00007f54b553f000)
libatk-1.0.so.0 => /lib/x86_64-linux-gnu/libatk-1.0.so.0 (0x00007f54b5ab6000)
libgio-2.0.so.0 => /lib/x86_64-linux-gnu/libgio-2.0.so.0 (0x00007f54b536b000)
libpangocairo-1.0.so.0 => /lib/x86_64-linux-gnu/libpangocairo-1.0.so.0 (0x00007f54b5aa5000)
libgdk_pixbuf-2.0.so.0 => /lib/x86_64-linux-gnu/libgdk_pixbuf-2.0.so.0 (0x00007f54b533c000)
libcairo.so.2 => /lib/x86_64-linux-gnu/libcairo.so.2 (0x00007f54b51f5000)
libpangoft2-1.0.so.0 => /lib/x86_64-linux-gnu/libpangoft2-1.0.so.0 (0x00007f54b5a8a000)
libpango-1.0.so.0 => /lib/x86_64-linux-gnu/libpango-1.0.so.0 (0x00007f54b518a000)
libfontconfig.so.1 => /lib/x86_64-linux-gnu/libfontconfig.so.1 (0x00007f54b513c000)
libgobject-2.0.so.0 => /lib/x86_64-linux-gnu/libgobject-2.0.so.0 (0x00007f54b50db000)
libglib-2.0.so.0 => /lib/x86_64-linux-gnu/libglib-2.0.so.0 (0x00007f54b4f94000)
libfreetype.so.6 => /lib/x86_64-linux-gnu/libfreetype.so.6 (0x00007f54b4ec8000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f54b5a83000)
libexpat.so.1 => /lib/x86_64-linux-gnu/libexpat.so.1 (0x00007f54b4e9d000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f54b4e7e000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f54b5a7e000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f54b4d93000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f54b4a00000)
/lib64/ld-linux-x86-64.so.2 (0x00007f54b5c86000)
libxcb.so.1 => /lib/x86_64-linux-gnu/libxcb.so.1 (0x00007f54b4d69000)
libXext.so.6 => /lib/x86_64-linux-gnu/libXext.so.6 (0x00007f54b4d54000)
libgmodule-2.0.so.0 => /lib/x86_64-linux-gnu/libgmodule-2.0.so.0 (0x00007f54b4d4d000)
libXfixes.so.3 => /lib/x86_64-linux-gnu/libXfixes.so.3 (0x00007f54b4d45000)
libXrender.so.1 => /lib/x86_64-linux-gnu/libXrender.so.1 (0x00007f54b4d38000)
libXinerama.so.1 => /lib/x86_64-linux-gnu/libXinerama.so.1 (0x00007f54b4d33000)
libXi.so.6 => /lib/x86_64-linux-gnu/libXi.so.6 (0x00007f54b4d1f000)
libXrandr.so.2 => /lib/x86_64-linux-gnu/libXrandr.so.2 (0x00007f54b4d12000)
libXcursor.so.1 => /lib/x86_64-linux-gnu/libXcursor.so.1 (0x00007f54b4d06000)
libXcomposite.so.1 => /lib/x86_64-linux-gnu/libXcomposite.so.1 (0x00007f54b4d01000)
libXdamage.so.1 => /lib/x86_64-linux-gnu/libXdamage.so.1 (0x00007f54b4cfc000)
libmount.so.1 => /lib/x86_64-linux-gnu/libmount.so.1 (0x00007f54b4cb0000)
libselinux.so.1 => /lib/x86_64-linux-gnu/libselinux.so.1 (0x00007f54b4c83000)
libharfbuzz.so.0 => /lib/x86_64-linux-gnu/libharfbuzz.so.0 (0x00007f54b48f9000)
libpng16.so.16 => /lib/x86_64-linux-gnu/libpng16.so.16 (0x00007f54b4c4b000)
libjpeg.so.8 => /lib/x86_64-linux-gnu/libjpeg.so.8 (0x00007f54b4876000)
libxcb-render.so.0 => /lib/x86_64-linux-gnu/libxcb-render.so.0 (0x00007f54b4c3b000)
libxcb-shm.so.0 => /lib/x86_64-linux-gnu/libxcb-shm.so.0 (0x00007f54b4c36000)
libpixman-1.so.0 => /lib/x86_64-linux-gnu/libpixman-1.so.0 (0x00007f54b47ca000)
libfribidi.so.0 => /lib/x86_64-linux-gnu/libfribidi.so.0 (0x00007f54b4c18000)
libthai.so.0 => /lib/x86_64-linux-gnu/libthai.so.0 (0x00007f54b4c0d000)
libffi.so.8 => /lib/x86_64-linux-gnu/libffi.so.8 (0x00007f54b47bd000)
libpcre2-8.so.0 => /lib/x86_64-linux-gnu/libpcre2-8.so.0 (0x00007f54b4722000)
libbz2.so.1.0 => /lib/x86_64-linux-gnu/libbz2.so.1.0 (0x00007f54b470f000)
libbrotlidec.so.1 => /lib/x86_64-linux-gnu/libbrotlidec.so.1 (0x00007f54b4702000)
libXau.so.6 => /lib/x86_64-linux-gnu/libXau.so.6 (0x00007f54b46fc000)
libXdmcp.so.6 => /lib/x86_64-linux-gnu/libXdmcp.so.6 (0x00007f54b46f2000)
libblkid.so.1 => /lib/x86_64-linux-gnu/libblkid.so.1 (0x00007f54b46b7000)
libgraphite2.so.3 => /lib/x86_64-linux-gnu/libgraphite2.so.3 (0x00007f54b4690000)
libdatrie.so.1 => /lib/x86_64-linux-gnu/libdatrie.so.1 (0x00007f54b4687000)
libbrotlicommon.so.1 => /lib/x86_64-linux-gnu/libbrotlicommon.so.1 (0x00007f54b4662000)
libbsd.so.0 => /lib/x86_64-linux-gnu/libbsd.so.0 (0x00007f54b464d000)
libmd.so.0 => /lib/x86_64-linux-gnu/libmd.so.0 (0x00007f54b463e000)
/opt/FreeFileSync/FreeFileSync "/mnt/SAMSUNG_300GB/Bureau Linux/FreeFileSync/BatchRun.ffs_batch"
echo $?
(FreeFileSync_x86_64:3686): Gtk-WARNING **: 19:03:08.395: Unable to locate theme engine in module_path: "adwaita",
0
