Hi all,
I'm constantly running into this error where the file "xxx.ffs_real" cannot be found and this is causing the RTS to fail.
The file (xxx.ffs_real) was previously created however it was subsequently deleted.
I am wondering if anyone can advise, what is pointing RTS to find this file? Where in an XML can I find this mysterious string that I can delete?
I've looked around the folders, checked the globalsettings but there are no references there. FFS has also been reinstalled but the error still shows up.
Have I overlooked something or is there a setting that I'm missing somewhere as when I looked at RTS folder, there are no settings.
Appreciate if someone can give me a pointer.
Thank you.
Cannot find file "xxx.ffs_real"
Figured out.
I had a startup at shell:startup.
Silly me...
Thanks guys.
Silly me...
Thanks guys.
