Some of the files that I regularly sync are of a .db file extension, they are a database for an application that several clients use.
When I have Real Time Sync setup to monitor a directory I can see that it spots a change in the .db file, goes through the motions of a sync and says completed etc.
However when I go and examine the 2 files the 2nd one will not have update and is of the same time stamp and content as it previously was.
Is there anyway to resolve this?
.db file extension
How do you know the db file is what caused the RTS trigger? Check the FFS log to see what it actually did.
