computer to computer
Myszek512
Is it possible to use FFS to sync files from computer to computer directly? Using USB cable, crossover ethernet cable, or on a LAN, if so, how? For now, I am using FFS two-way to sync d:\documents\ to a USB passport drive then sync passport drive to laptop d:\documents & back.
Seems like there should be some way to sync directories directly from workstation to laptop.
Thanks,
Rob M
https://support.microsoft.com/en-us/windows/file-sharing-over-a-network-in-windows-10-b58704b2-f53a-4b82-7bc1-80f9994725bf
Once you get a network share working, FFS can use that network location just like any other storage location. Mapping the network share using the hosting computer's name is usually a good recommendation.
