Error reading BTRFS mount on windows
kcswalter
Hello
I have a BTRFS partition mounted with WinBtrfs. Until a few weeks ago, the sync with a remote server was working fine, but now I always get error code 0x54f, internal error, DirReaderPlus::readDir while reading the local partition.
I can access that partition perfectly with all other software installed on the PC, so I really don't know what happened and why it's not working anymore.
Any suggestion?
What have you tried?
Looks like we need a fall back from DirReaderPlus to standard file traverser. Can you post the full error message you're getting with the following beta: https://www.mediafire.com/file/9rpvyq26xed1uah/FreeFileSync_11.18_%255BBeta%255D_Windows_Setup%25284%2529.exe
kcswalter
Hi
sorry for the delay.
I did try uninstalling and reinstalling FFS. I also did a scrub on the partition from Linux, and I did check and reapply uid, gid and permissions. Nothing worked. All other softwares that I have use the partition normally (my Documents are in fact stored there).
After installing the beta you gave me and rebooting, it started working again. I've no idea what changed from before.
