How to backup other users account folder?
nsjwh
thank you for coding this software, seems to be what I need.
One issue though: On Windows, as a user with admin rights, how do I backup a user folder from another user? It simply does not show up in the list.
Thank you
In what list? Navigate to "C:\Users\" and the other folder should be there.
nsjwh
In what list? Navigate to "C:\Users\" and the other folder should be there. xCSxXenon, 08 Mar 2022, 22:28
Well, they are not. That is the issue.
There is something wrong with your Windows then.
nsjwh
There is something wrong with your Windows then. xCSxXenon, 09 Mar 2022, 15:29
Excuse me, I'm an idiot.
When I created the profile for FFS I excluded most of the other users' folders and just yesterday I wanted to start backing them up. I just checked all the Windows/NTFS access rights and did not spot any problem - I also (thought) I made a new FFS profile by just changing the folder paths (which did not create a new one) and then I had the bright idea to check the filters - well, found the culprit.
Sorry, all fine.
