I love FFS but I cant use it proably with a proxy.. is there any solution (any conifg file I can change manually or so?)
Please dear Developer add some textbox with proxy support :/
Best regards,
Louis
Google Drive: Proxy Server Support please!
Probably? why not?
Could you try running the program with an environment variable set:
And check to see if that works?
Now, if you are trying to use one of those "cloud" solutions like Google Drive, you should test with variable https_proxy. Let's see if the program uses whatever it is that uses those variables, probably glibc or something.
Edit: Oh, sometimes the environment variable name needs to be in all caps. So try FTP_PROXY, FTPS_PROXY, HTTP_PROXY and all those variants.
ftp_proxy=http://proxyname:3128 /path/to/FreeFileSync
Which OS? HTTP access on Windows uses Internet Explorer settings (including Proxy support) automatically.
Windows 10. Proxy Server is set in Internet Explorer etc. When I use Proxifier it works but I wanna use FFS without it. So it seems it doesnt regognize the System Proxy. There are some other users here which said the same :/Which OS? HTTP access on Windows uses Internet Explorer settings (including Proxy support) automatically. Zenju, 11 Mar 2022, 07:53
Is it possible to work with environment variable in this case?
Best regards,
Louis
Thank you so so much man!Could you try running the program with an environment variable set:And check to see if that works?ftp_proxy=http://proxyname:3128 /path/to/FreeFileSync
Edit: Oh, sometimes the environment variable name needs to be in all caps. So try FTP_PROXY, FTPS_PROXY, HTTP_PROXY and all those variants. bgstack15, 11 Mar 2022, 00:58
Setting HTTP_PROXY and HTTPS_PROXY in the Env Variables fixed my problem!
Have a wonderful day!
Best regards,
Louis
So the issue was with Google Drive? If so, I could add automatic support so that libcurl fetches the proxy config of Internet Explorer.
Yes! Tried to connect to my Google Drive in this Scenario!So the issue was with Google Drive? If so, I could add automatic support so that libcurl fetches the proxy config of Internet Explorer. Zenju, 11 Mar 2022, 10:20
even configuring the proxy in internet explorer/system, when being redirected to the google authorization page and confirming the access of FreeFileSync, when returning to the app, it tries to make a direct connection with the IP, without using the proxy.
Windows 10 Pro (21H2)
Implemented for FFS 14.8! The system proxy will be detected automatically and used for GoogleDrive:
https://www.mediafire.com/file/6unlr9zzksn3o5t/FreeFileSync_14.8_%255BBeta%255D_Windows_Setup%25282%2529.exe
PS: the old hack to use environment variables is still supported, but they need to be in *lower* case:
set http_proxy=127.0.0.1:8888
set https_proxy=127.0.0.1:8888
PPS: there should also be manual proxy support for other protocols, but it is untested: ftp_proxy, ftps_proxy
Reference: https://curl.se/libcurl/c/libcurl-env.html#schemeproxy
