Sync timestamps only?
troels
Is it possible to sync timestamps (without copying)? I have over 20TB to download from Gdrive and repopulate a NAS. For some reason the timestamps on some files are out of sync so a comparison by date and size flags mismatches.
I tried the option to apply an offset but the differences are not all the same.
Is there a way to only sync timestamps? If not, can this be considered as a feature request?
I don't want to turn off comparison by date and size and so far the only way I've been able to sync the timestamps is by using a competing product, Synocovery, which has this exact option. In all other respects though it is a far inferior and frustrating product but this option quickly did what I needed.
