but the installation stops and i have to press ENTER to continue with the default parameters
1. Install for all users: YES (requires root password) 2. Installation directory: /opt/FreeFileSync 3. Create desktop shortcuts: NO _____________________________ Press a number [1-3] to change settings, ENTER to begin installation:
Is there an option for this part and accept the default parameters of the installation on Linux? Thanks
PD: I didn't find anything about linux in the documentation
bgstack15
If you cannot find anything in the documentation about that, you could use the program "expect" to script interacting with this install script. I haven't used expect in quite a while so cannot give you a specific example, but it would basically look for the line of text that represents the question "ENTER to begin installation:" and then it could "type in" the number 3. Or whatever your choices are.
acg
bgstack15, 19 Mar 2022, 23:47
that's exactly why I'm asking the question, to avoid using the expect command, which is what I currently do
h___m
There are more options. This command installs without interrupt:
