Easily show conflicts
Allie
I LOVE FreeFileSync and happily donate. Best backup/sync program I have ever used. Thank you for making it happen!
Suggestion and maybe I've missed it: I have wasted far too much time attempting to find the files with conflicts. It would be nice to have a way to simply click and display conflicted files so that then sync to right, re-run, and all files are correctly synched.
Again, if I have missed an easy way to do this, my apologies.
After running a compare, there are buttons at the bottom-middle that allow you to show/hide sync lines based on what FFS determined their statuses are.
Allie
Thanks. Appreciate the input and I'll know what to do when I run my next sync.
pnachtwey
Allie, good idea! I have the same request. I always display the conflicts so the show conflicts buttons would be better for finding the conflicts in a long list of files. An option to use the conflicts button as it is or to simply go to the next conflict would be great.I use FFS to synchronize my NAS. At first there were a lot of conflicts but not so many anymore.
