I installed FreeFileSync today on my M1 Mac. I read this page:
I used Finder to search for GlobalSettings.xml and it cannot find it. I want to use VerifyCopiedFiles. Can someone help me? Thank you.
By the way, why isn't this option in the GUI? It seems like it is something that I should be able to just put a check mark on to get the verify function. Editing a hidden file that I cannot even find seems to be very kludgy. Anyway, that is my opinion. :-)
Cannot find GlobalSettings.xml
Here is a screenshot of ~/Library/Application Support and, as you can see, there is no FreeFileSync folder.
What is shown as the "default log path" in app menu > preferences?
Thank you for the information. I found it and edited the GlobalSettings.xml file.
Why isn't this option in the GUI? It seems like it is something that I should be able to just put a check mark on to get the verify function.
