new config file format in v3.17
ruleant
I noticed some changes were introduced in the config file, with the release of
v3.17. Is there a way of converting configfiles automatically to the new
format?
Kind regards,
Dieter
Use the converter:
[404, Invalid URL: https://sourceforge.net/projects/freefilesync/files/freefilesync/v3.17/]
zespectre
Are there instructions for this somewhere? All I get when running the .exe is
"Please Specifi a *.ffs_gui or *.ffs_batch file as input argument!"
Simply drag and drop the config file onto the converter executable.
zespectre
that works...thanks!
