How to sync with two windows 10 PCs
hongsoogkim
Hello everyone!
I'm newbe to FreeFileSync.
I want to synchronize the folder between two windows 10 PCs using FreeFileSync (donator edition).
My specific constrains are as follows:
- old Windows 10 PC is full of HDD slots, hence I cannot attach new HDD.
- old and new Windows 10 PCs are connected in the same network
- I cannot use Network Folder sharing feature in Windows 10 PCs due to company security policy
I'm considering with SFTP on new Windows 10 PC.
What is best practice of file/folder synchronization with above constraints.
Is there tutorial or howto document for this subject?
Thanks for your reading and help/tips in advance!!
You can select network location in FFS, You should look up how to set up network shares and then jump here to work with FFS
