multiple definitions of disks instead of a drive letter
pope5
FreeFileSync allows the definition of the name of a backup disk to be used instead of a drive letter.
As usually for security reasons more than one backup disks are used in a wrap around mode, it should be possible, to define also more than one name for backup disks.
E.g. [Backup1][Backup2][Backup3]\Documents .
If more than one of the named disks are connected to the pc at backup time, the first disk found is used for backup.
