repeated read error from cloud
petermi
As the Onedrive and Google Drive apps are no longer supported on my older MacOS I am using FreeFileSync Donation Edition to sync with them in the cloud, after running an app Cloudmounter to mount Onedrive and Google Drive to be seen as ordinary folders on my iMac. It works OK but only with repeated errors due to delay in fetching the data. It will sync a few files then stop with the error, then a few more after restarting, until eventually I finish the sync. So I can't leave it alone, I have to keep restarting the sync multiple times. Is there some way I can make FreeFileSync have a higher threshold for giving the error, e.g. try more times to read the file, or wait longer for the data to download?
