Sync only folders
svnkn
Hey folks!
Is it possible to sync only the folders without the subfolders or files?
I already tried different exclude phrases, but didn’t get it to work.
Thank you for your help!
https://freefilesync.org/manual.php?topic=exclude-files
Exclude:
All subdirectories of the base directories *\
svnkn
Exclude:
Zenju, 31 Mar 2022, 11:31
That didn't work for me.
I want the following:
==> Source Folder Example
        - Folder 1
            /File 1.txt
            /Folder 1.1/File 2.pdf
            /Folder 1.2
        - Folder 2
            /File 3.png
            /Folder 2.1/File 4
        - File 5.pdf
==> Sync Folder
        - Folder 1
        - Folder 2
The exclude code
Did the following:
        - File 5.pdf
So you don't want any files to sync? Just the directory names?
svnkn
Exactly!
Backitup
You can try the following: Xcopy with the /T switch
/T Creates directory structure, but does not copy files. Does not
include empty directories or subdirectories. /T /E includes
empty directories and subdirectories.
Not tested by me.
svnkn
Not tested by me. Backitup, 22 Jun 2022, 17:53
Can I trigger this on folder creation?
You could use RTS to monitor the directory and run that command upon any changes.
        - Folder 1
            /File 1.txt
            /Folder 1.2
        - Folder 2
            /File 3.png
            /Folder 2.1/File 4
        - File 5.pdf
==> Sync Folder
        - Folder 1
        - Folder 2
svnkn, 31 Mar 2022, 11:43
Use ?*\?* as exclude filter to get rid of items in sub folders.
?* means "one or more" characters.
To get rid of the files in base folders, you can use an include filter of ?*\ (folders only) or an exclude filter of *: (files only, requires FreeFileSync 11.24).
See (updated): https://freefilesync.org/manual.php?topic=exclude-files
GKN
I used the following and it worked.
- Add the folders in the Include (for eg : \MyFolder\ to copy the structure from MyFolder and its sub folders)
- Add *.* in the Exclude
Include:
\MyFolder\
Exclude:
- Add *.* in the Exclude GKN, 10 Dec 2024, 12:31
This isn't a correct answer for the thread as the OP doesn't want subdirectories.
GKN
Agree XCSxXenon... Sorry I misread it as wanting the subfolders but not the files.
