FFS shows me old synchronisation data under "Last synchronisation", e.g. 4 days old. However, under C:\Users\MyName\AppData\Roaming\FreeFileSync\Logs the current synchronisation can be seen. What have I done wrong or set up incorrectly?
Addendum: This behaviour is the case when FFS runs via batch. If the synchronisation is triggered manually, the correct date is displayed.
Thanks in advance for the help.
Roland
Wrong Date in "Last Synchronisation"
Thank you for the answer. Today the date is displayed correctly. Why I do not know. Maybe it's because of synchronisations between different computers.
Many greetings
Roland
Many greetings
Roland
