Progress chart
jonpeddie
I did something that removed the progress chart and I would like to get it back. I have read there is a minimize button somewhere, but I can't find it.
You have to re-save your sync as a batch job and uncheck the "Run minimized" box
jonpeddie
Didn't work. Although the progress chart flashed at the end. Do you think a reinstall would help?
