2 way sync not working properly
Peter Bomberg
I have 2 laptops I want to keep synced, however I only travel with one so I set them up to both sync against google drive.
Laptop A <-> Google <-> Laptop B, this seems to work well for additions but for deletions what is happening is that A deletes, it propagates to google but B thinks it's newer so it updates google which then propagates to A and presto I am back to square one.
Any ideas or suggestions?
Make sure you are using two-way on both laptops when syncing to Google Drive
Peter Bomberg
Thank you and they were. So sadly not that simple.
After deleting a file from A and then that also being deleted from Google, run just a compare on B and share the compare window.
