Realtime Sync not automatically adding Command Line
Gordonbp
Realtime Sync 11.8
As in the subject.
You clicked and dragged a ffs_batch file onto the RTS window
Gordonbp
No. The Help said the app would automatically create the command line.
The Help says it does so when you import an ffs_batch file via Menu → File → Open or simply via drag and drop.
If you manually configure RTS, you need to define not just the folders to be monitored yourself, but also the command line that is to be executed.
