It's a small thing. Doesn't minimize or go away after RUN
jackdashack
Hello and thanks for getting this far.
Somehow in the course of reinstalling FreeFileSync I don't get the GUI to go away after a successful Run. It's runs from a scheduled task, very well. But there it is, hanging on the desktop when done.
As I said it's a small thing. I'm not sure I'm finding how to close that out each session or run.
Appreciate your time and answer. jack ":-Dx
Did you save the sync as a fffs_batch file and check the "Run minimized" box?
jackdashack
xCSxXenon: yes I do run as a batch but somehow I missed the "run minimized" ... I'll have to investigate and see how to do that now. Thanks!!!
