Hi There,
I was testing your application with Google Workspace that I faced this error.
Any Advise?
Thanks,
Google Drive Copy File Failed!
I've had the same issue, but I observed that it's related to file that are not in the PC; in my case the extensions are *.gdoc and *.gsheet, but they are only link (file dimension under 1kB).
My GDrive setup is "streaming" so not all the file are mirrored between local folder and cloud; for some files only a link is present.
