sync file problem
lyjhf2006
when i sync a large file, the software make a larger temp file, that making error ,showing no more space.
can the software provide a small temp file backup instead of a large temp file?
each folder for backup then delete the temp file for release space.
You can not influence the size of *.tmp files in FFS,
but if you absolutely need it, you can disable the creation of the *.tmp files.
See here.
The tmp files are on a file-by-file basis, not for whole directories.
