Thumbnails not showing on destination folders
indiangamercompany
I am using two way sync, included \thumbs.db in filters, still not getting thumbnails. What should I do to get thumbnails in destination folders. It is not a windows settings issue.
Did you remove that entry from the exclude filter?
indiangamercompany
yes i did, it is \thumbs.db i think which I included in filters and removed from excluded filters.
indiangamercompany
Issue was only with files i had shot on very old mobile, there is no problem with other files.
Issue resolved
