Hello. I use Audio- Expert on my Windows11 PC to manage my songs. I regularely sync my Digital Audio Playewr DAP using FFS. I now realize that I amended the song type (country, Blues, Rock etc) on some songs on the PC and synced only to find out, that the target drive (DAP) did not get updated.
Can this criterion be included in the match somehow? Thanks for support.
noffie99
Attributes to identify that sync needed
You can use "File content" to detect these changes as well.
thanks for the speedy reply. Will check soonest.
Unfortunately this did not work either.
I modified some music styles (genres) in Audio Expert, validated the change using MP3TAG which showed the change and then sync. Changes not selected.
Also modified some song attributes directly in MP3TAG which did not work either.
Any suggestions?
Any suggestions?
