File or folder name not suport chinese?
Most likely issue is the server not using the UTF8 Unicode encoding.
I change the sftp server to support UTF8 Unicode encoding version. The problem does not happen againMost likely issue is the server not using the UTF8 Unicode encoding. Zenju, 03 May 2022, 07:43
Thank you. It helped.
