Shared folder on W11
gioreva
Maybe is a problem only on W11
When I compare with a external shared folder, FFS tells me that waits because the folder is busy.
It refer wrong user name.
Explorer and also FFS selector acces correctly to folder and file.
Username external is stored in Explorer.
What's the exact message? Sounds like there is a .ffs_lock file in the location that it is referencing, which tells FFS that another FFS session is currently running on that same location.
gioreva
In attesa mentre la directory รจ in uso: "Z:sync.
Waiting while the directory is in use: "Z: Sync.
While I wrote he unlocked hitself.
Now the compare does it, but does not copy any files.
Impossible to read the "Z:\agitator" permits
I associated Z but if I use the network folder it is the same.
gioreva
ERROR_ELEVATION_REQUIRED: AdjustTokenPrivileges(SetSecurePrivilege)
