I have a RealTimeSync profile setup.. and subsequently I have thousands of
log files.
How do I disable logging for this profile, also, how do I do this for other
profiles ?
How do I change logging options e.g. change the location that the log files
are stored?
Thanks..
Log files, directory and options?
FreeFileSync always writes a logfile when running in silent mode. But you can
select the directory where those logs are stored: In batch creation dialog
there is a separate tab named "Logging" where you can specify a path.
Consider this a feature request: allow for the possibility of a single log
file per batch job (all invocations), one file per day, or one file per
invocation.
For now, I think I'll work up a batch job to zip up all log files older than a
week or so.
invocation.
week or so.
Hello
I can't find any tab in the batch creating dialog with the name Logging.
Can I edit the batch file and specify the path into the file?
Logging tab becomes active when setting "silent" checkbox.
