cannot write file, xxxxx already used by another item....
version 11.2.0
please help me with this
There is already a file with that name in the destination. Either remove one of the copies or rename one of them.
Appears ? the "prefixes" of the file names are different?
The "_GlaceEorzea #Clear Bright.png" part looks to be the same.
(Looks can be deceiving ;-).)
But the prefixed ISO 8601 date part is different - if that's what the issue is - based on the visible parts of the file names.
It completes the synchronization after I deleted somefiles.There is already a file with that name in the destination. Either remove one of the copies or rename one of them. xCSxXenon, 11 May 2022, 14:54
and..I tried to put these files back to sync, the same problem again.
I think maybe It's because of these files' names
please help me check them is ok
It completes the synchronization after I deleted somefiles.Appears ? the "prefixes" of the file names are different?
But the prefixed ISO 8601 date part is different - if that's what the issue is - based on the visible parts of the file names. therube, 11 May 2022, 15:11
The issue is there are multiple files with the same name on your Google Drive. FFS doesn't allow this, but Google Drive does. So you need to open Google Drive and delete the duplicate variants manually.
I deleted the folder on google driver and retrying again, still can't write.The issue is there are multiple files with the same name on your Google Drive. FFS doesn't allow this, but Google Drive does. So you need to open Google Drive and delete the duplicate variants manually. Zenju, 12 May 2022, 08:01
Sorry, I was confusing the error message with "The name %x is used by more than one item in the folder.".The issue is there are multiple files with the same name on your Google Drive. FFS doesn't allow this, but Google Drive does. So you need to open Google Drive and delete the duplicate variants manually. Zenju, 12 May 2022, 08:01
It's okay. I think it's because of the file name. I'll try changing all the filenames later and try again a few times.Sorry, I was confusing the error message with "The name %x is used by more than one item in the folder.". Zenju, 12 May 2022, 15:20The issue is there are multiple files with the same name on your Google Drive. FFS doesn't allow this, but Google Drive does. So you need to open Google Drive and delete the duplicate variants manually. Zenju, 12 May 2022, 08:01
But since windows supports this naming scheme, FFS should support it too.
