For testing, I have create a source folder with a text file in which I have added a new user with only read permissions. When I sync and the file is copy the destination folder, in permissions of the file, I can't see this user, it takes the permissions of the parent folder.
There is some way to copy the permissions of the files and folders?
Thanks.
Is it possible to keep the user permissions of the files?
