I have created a batch file in FFS and it works well in FFS.
Then I open RTS and I drag and drop this batch file to it and save it to batch real time file.
Then I close RTS and double click the real time batch file that I have created. it syncs the folder correctly, but after it finished, in the icon tray RTS tells that there is an error and the it stop to work, new changes in the source folder is not detected.
I gue this error:
Fallo del comando ""C:\Program Files\FreeFileSync\FreeFileSync.exe" "C:\Users\Administrator\Desktop\Asus - batch.ffs_batch"".
Código de salida 1
How could I solve the problem?
Thanks.
In RTS, command fail, output code 1
Make sure you drag and drop your .ffs_batch config, from File Explorer, onto the RTS window. This ensures the command is grammatically and syntactically correct, as that is usually the issue.
Thanks, this solve the problem.
