Error elevation is requiered
daimroc
I have a computer in which I am running FFS. I have a network folder in a remote computer. I want to mirror the network folder to the local computer, so the source is the network folder and the destionation is a folder in the local computer that is running FFS.
I few cases, when some file is trying to copy to the local computer, I get the error that I need to elevate privileges, because it is not possible to read the permissions of the file in the remote folder.
However, if I use the file explorer to check the file, I can read it an open it. Also I have checked the permissions and I have network permissions and file system permissions in the remote file for the user that is running FFS in the local computer.
So really I have permissions, but FFS gives me this error.
this is the complete message:
No se pueden leer los permisos de "\\1.1.1.1\MyFolder\MyFile.xml".
ERROR_ELEVATION_REQUIRED: La operación solicitada requiere elevación. [AdjustTokenPrivileges(SeSecurityPrivilege)]
Thanks.
daimroc
Thanks, that's solve the problem.
But I realized that this is a configuration at application level, I can't set this parameter in the batch file or for individual taks of sync.
Or i am wrong and it is possible to create a batch sync file that copy the DAL information and another batch file that doesn't do it?
Thanks.
It is not currently possible.
