date after sync are "sync date" and not "file create date" : sync went wrong
golfy038
Hi there,
sorry about my title which is not clear, but here is the explanation:
1) I've choose "Synchronization" for my first synchronization between a NAS folder (/mnt/myName/Projects) and my local folder (/home/myName/Projects)
2) FreeFileSync have create missing files from two sides (local and remote)
3) I'm asking to compare and now FreeFileSync propose me to sync ALL files from remote to my local
When I display date, remote date are the time of first synchronization
I'm on Linux Manjaro and I use FreeFileSync 11.21 with a Synology NAS. This folders (and files) were created with Win10, before my migration to Manjaro (ext4 for local, CIFS for remote)
If anyone has an advice or a tips to help me doing better sync... thanks !
This is most definitely a NAS or Linux issue. What happens if you copy the files manually from NAS to local?
golfy038
It works like a charm
https://i.imgur.com/0jamkk6
Can you make a screenshot of the error log when copying with FFS?
golfy038
yep of course!
No change have been done since last synchronization on 2016 folders and you can imagine I'm not modifying so much files in few days.
Even when running many time FreeFileSync, it has always lot of files to sync (often conflit with date).
I'm trying to change smb to nfs but I've some problem with permissions for now...
With no errors in the log, this means that setting modification times (using utimensat()) fails silently outside the control of FFS. This leaves only two explanations:
1. a bug in the NAS firmware
2. a bug in the software mounting the NAS (e.g. gvfs)
This is most definitely a NAS or Linux issue. What happens if you copy the files manually from NAS to local? xCSxXenon, 19 Jun 2022, 14:11
The other way round is the interesting case.
golfy038
Maybe it's NAS problem, maybe not.
If I used Unison, it works well : Unison isn't able to monitor files in real-time, but it does the job correctly.
Results with FFS aren't reliable for now :(
I'll give a try to lsyncd too if I've time...
dri
I have the same problem. You create a file locally, sync it to the NAS and the next time you sync, the file should be synced back to the client.
The NAS knows a change date and a creation date for a file. When syncing under Windows, FreeFileSync reliably transfers both values ​​to the transferred file. Not under Linux. When syncing, the time of copying is set as the change and creation date in the file on the NAS. This means that the synced file on the NAS is newer the next time it runs and should be copied back.
