Synchronization speed slows down dramatically when updating such files:
"\\TNAS-C34A\Works\AndroidStudioProjects\HealthSkin\app\build\intermediates\incremental\debug-mergeJavaRes\zip-cache\7+BJpUQ0in26V8Zcqg914INMi+M="
Log file in attachments.
Reducing the speed of synchronization with the NAS
Seems to be limited to the zip-cache items. How big are they? Are you using mechanical HDDs or SSDs? Is there actually a problem?
Files size 3kb - 500kb. Source - SSD, target - NAS (RAID0 HDD, EXT4). Similar synchronization to an external USB drive does not cause problems - there is no speed drop. When synchronizing with AOMEI, everything is also in order.
