I changed a few folder tags before syncing and notice that after synchronization these changes are not synced to the destination.
the configuration is set to "mirror".
if i create a new folder with tags, it is synced just fine.
Is it possible to also sync the modification if just only a tag has changed?
regards
freefilesync mac and folder tags
Tags don't get synced. On the first "sync", they do only because it's writing it for the first time. If you change a tag on its own, it won't sync. If you were to change the tag and some of the file's contents, it may update the tag also.
