I am a long time user of FreeFileSync and have recently started using
RealtimeSync. I have got it so that it starts automatically. However the
Minimum idle time always reverts to 10. Is there a way to change the idle time
to something larger in the shortcut command line? Thanks
Can Minimum Idle Time be added in the command
The default time of 10 sec is set for ffs_batch files only. If another time is
needed create a proper ffs_real file and use it in autostart instead.
Thank you , that works well. And thank you for developing such a great backup
program.
Roger
program.
Roger
