Greedy - non-greedy matches or differentiation between full path-filename only
d05register
Could you implement a non-greedy matching? I want to copy 01* files e.g only the 1st in this example
\foo\01 myFolder\01 myFile.txt
\foo\01 myFolder\other File.txt
If I include *\01* it matches the folder also so it copies all the files
If I add an exclude *\01*\ to exclude the folder only it matches again all, and copies nothing
A solution (I think) would be a non-greedy modifier (as in Perl is the "?" ) https://perldoc.perl.org/perlre
or something like this https://docs.syncthing.net/users/ignoring.html where an Asterisk (*) matches
any character but not the folder separator while Double asterisk (**) mathces any character including folder separators
therube
Is \01*\01* viable?
d05register
No. In include list it misses my main goal the 01* files e.g. case 3
1. \foo\01 myFolder\01 myFile.txt
2. \foo\01 myFolder\other File.txt
3. \foo\other Folder\01 myFile.txt
In exclude list I would need something like \01*\?!01* i.e. exclude only case 2 (01 folder\not 01 file)
Possible with FreeFileSync 11.24! viewtopic.php?t=9475#p34605
By appending ':' to the include filter, it will match files only:
*\01*:
d05register
Man it doesn't work (just updated to 14.9 from 13.9 to be sure).
Found some files in conflict because of the workarounds I use to overcome this case
Tried a new clean test case. I want to mirror all files starting with 01
I use *\01*:
No matter what, it selects also folders starting with 01SomeFolder\ with all its files which is Wrong
Please fix
Well, technically your filter is including all files whose path starts at the root of the base location and starts with "01". The ending asterisk is a wildcard that catches everything, even subfolders, in each file's path. I don't know the solution at this moment, but that at least explains the behavior.
d05register
Yes but this is wrong
Even if you use *\01*.pdf:
i.e. two indicators that you want to match files only, one is the :, and the other is the .pdf
it again mathces whole paths e.g. 01SomeFolder\SomeFile.pdf
So if you have folder prefixes common to file prefixes you are FUBAR. You can't match only the files
This ruins an otherwise so good software, it's a pity
If all files with a name starting with 01 have the same folder depth to your left and right base location, you should still be able to do it.
As per your example:
If foo is the direct child of your base location, you should be able to
Include \foo\*\01*: or even *\*\01*: and
Exclude \foo\*\*\* or even *\*\*\*
If foo is your base location, you should be able to
Include *\01* and
Exclude *\*\*
