Feature Request: Sync ONLY folder structure in Windows
markiloon
i hope FFS can Sync ONLY folder structure in Windows. (i don't want to use Xcopy nor Robocopy.)
many thanks!!
markiloon.
It can't. Use robocopy or xcopy
Possible with FreeFileSync 11.24:
Enhanced filter syntax to select files only (append ':')
https://www.mediafire.com/file/dlf4xzippf8d9fl/FreeFileSync_11.24_%255BBeta%255D_Windows_Setup.exe
Just set *: as exclude filter . See https://freefilesync.org/manual.php?topic=exclude-files
markiloon
that is great!! many thanks!!!
