Move files older than...
Homercidal
Apologies if this has been asked, or seems easy. I want to gradually move some data from an egineering drive to a backup location on the network.
Ideally I would find files that are from a certain date and older and MOVE those files (copy then delete, whatever). Example: Find files from 12/31/200 and older and move them to the destination.
It feels like this should be simple, but I'm not understanding a good way to do it.
Thanks for any advice you have!
-Homer
I don't think there is any built-in way to do this with FFS. Typically, moving data in chunks by directory makes more sense unless you are moving a bunch of files in a single folder. If you're doing that, a forfiles command would probably be better anyway.
