I'm using Win7 x64, and after creating an RTS set, I was looking through task
scheduler to find it in case I needed to edit, delete, or disable it.
Unfortunately, I can't find it anywhere, and I don't have a complicated
schedule set at all. I don't even know if it's working. Does it run via
scheduled tasks?
Where does RealTimeSync put jobs?
RealtimeSync doesn't use Windows Task Scheduler to start sync jobs. All it
does is execute the commandline at certain times, which in most cases just
starts a FFS batch job. Therefore RTS has to be running (= big start button)
in the background to provide its service.
