Some folders won't sync to SD card in phone, only gives like this:
"06:34:10 Feil Kan ikke flytte filen
"mtp:\Lars-Erik's A33\MOBIL SD\Dokumenter\E-post\LarsErik\000000BA~25fd.ffs_tmp" til
"mtp:\Lars-Erik's A33\MOBIL SD\Dokumenter\E-post\LarsErik\000000BA.DAT".
Feilkode 0x80004005: Uspesifisert feil [IPortableDeviceProperties::SetValues]"
If I delete the folder and create it over again it works again - the first time.
But when I files should be updated it fails.
But this doesn't happend in all folders. Seems like it's an attribute thing.
Is there a way to set "do not copy attributes" when copying to phone?
Addition: If I turn off "save file copy" the error message changes to:
"06:58:38 Feil Kan ikke opprette filen "mtp:\Lars-Erik's A33\MOBIL SD\Dokumenter\Web sider\osterud.name\dj-leo\Spilleplan – Kopi.html".
Feilkode 0x80004005: Uspesifisert feil [outStream.Write(buffer, static_cast<ULONG>(bytesToWrite), &bytesWritten)]"
Trouble syncing SD card in Android phone - Again
