Hi. I surely must be missing something simple here.
The Default Log Folder location is set in Tools-> Options. When I create and run a batch job it writes to that location as it should. However, looking at the saved .ffs_batch file in a text editor I can see the XML and there is an element <\LogFolder>. This never gets populated even when I change the location in Options. Batch files seem to automatically use the default location.
I understand the need to have a default location defined globally but is it possible to define the logfile folder differently for different batch files? If so where would I achieve that and where would that setting get stored?
I have tried entering a location into that <LogFolder/> element in the XML Batch file using other address entries for their format as in:
" <LogFolder>G:\My Documents\FFS Logs\Different</LogFolder>"
That allows the file to load up without error but still uses the default directory when it runs so it is obviously not that simple. If I then resave the batch file I find the <LogFolder/> element has now been populated with the Default location where I had entered a specific test location when I edited the XML.
Confusion about Log File Location storage.
I've got this in my .ffs_batch file (& presumably ? similar could be in .ffs_gui, but not sure offhand?):
(If you have physical quotes in your file, you do not want that.)
<LogFolder>G:\DEV\BACKUP\FFS_LOGS</LogFolder>
No physical quotes in mine either therube, they were just there to show the extent of the XML entry. Is that G:\DEV\BACKUP\FFS_LOGS address the same as your default folder specified in Tools->Options?
